'95 Disc. Noise/Rattle
RE: '95 Disc. Noise/Rattle
I have the same noise, but haven't taken the time to find it for sure. I have tightened all of the body bushings, and replaced my shock bushings. I think it may be the bushings for the lower link on the rear. ( the bars that go from the frame to the rear axle ). I think if you can get someone to bounce in the back of the truck while you are under it, you can find it. I haven't taken the time to investigate this, and it's been too cold. Also make sure there is enough clearance so you don't squish your head....[sm=partyparty.gif]
Good Luck.
Jason
Good Luck.
Jason
euronavdiscs
02-06-2016 03:41 PM
