Noise/Rattle from exhaust
Old Sep 2, 2009 | 08:41 PM
rich's Avatar
5th Gear
Default Noise/Rattle from exhaust
I have a 2001 RR. When it is cold, there is a rattle/noise from the middle section of the exhaust. Most of the noise stops when it warms up. Or I can stop it by holding the heat shield.
Any idea of what it is?
Is this the cat or a muffler? What is likely replacement cost?
Thanks
Rich
Old Sep 3, 2009 | 12:39 AM
LRScott's Avatar
Where abouts is it on the exhaust system? I know you said middle, but can you be more specific. If it is a heat shield, you can usually tighten the bolts and the rattle will stop.
Old Sep 7, 2009 | 12:59 PM
rich's Avatar
5th Gear
Update:
After some suggestions that it might simply be the heat shield, I found a repair suggestion on following website. I restained the heat shield using the exhaust by using 4 large hose clamps. I will say that it has only seen about 50 mils since then so time will determine the success. So far so good.
http://www.rangerovers.net/repairdetails/catalytic.html
Hare
Dec 1, 2012 06:37 PM
CarlDisco
Jun 21, 2012 09:07 AM
errose2002
Feb 28, 2011 12:17 AM
starcraft
Mar 7, 2008 08:08 AM
jbond0076
Apr 9, 2007 11:04 PM
