95 disco overheating
so im reading through rave, and it doesn't mention using rtv sealant on the thermostat gasket. should i use it or not? also, i missed reading the part where is says that i have to use loctite on the 11mm water pump bolts. should i remove the bolts and add some loctite?
also, step 8 for the thermostat section says "Fit the outlet elbow and new joint washer.
Tighten to 28 Nm." is a new joint washer a gasket?
i read the sticky on how to bleed the cooling system for the d2 and it mentions that there is no air bleed on the d1. .
oh yeah and my drive belt was routed wrong, even though i triple checked the routing before and after it was installed. i think i might have been looking at the wrong diagram. routing the belt correctly helped the cooling problem a bit but it still runs hot. so i installed a new vicious clutch today and i will be testing her out first thing in the morning.
