'95 tune info pls
'95 tune info pls
I just was given a '95 Disco a while ago. Didn't even have the standard operator's manual with it. Thought I had some time to finish someone else's "work in progress" but my PU truck died today so I need to get the Disco going quickly. To do that, I need three pieces of info:
1.) A schematic/diagram of the spark plug wires from each port on the distributor cap to each spark plug port.
2.) The correct spark plug gap for a 95 Disco
3.) Can someone tell me the location of the fuel filter? I've looked but can't identify it.
As you can probably see from my questions I am no mechanical genius, but if I can get this info I can probably get it running. Thanks in advance to anyone who can help me.
on
RE: '95 tune info pls
I would also suggest you order a factory only, cap and rotor and be very carefull removing the rotor, they can be hard to remove and you can damage the lower workings of the distributor if you hit or bang on the rotor.
Since this is a new vehicle for you, e-mail me with your tel number and I will send you a complete list of everything you need to do to this truck to make it current.
