'95 tune info pls
Old Jan 3, 2009 | 07:48 PM
Fishcamper's Avatar
Default '95 tune info pls
I just was given a '95 Disco a while ago. Didn't even have the standard operator's manual with it. Thought I had some time to finish someone else's "work in progress" but my PU truck died today so I need to get the Disco going quickly. To do that, I need three pieces of info:
1.) A schematic/diagram of the spark plug wires from each port on the distributor cap to each spark plug port.
2.) The correct spark plug gap for a 95 Disco
3.) Can someone tell me the location of the fuel filter? I've looked but can't identify it.
As you can probably see from my questions I am no mechanical genius, but if I can get this info I can probably get it running. Thanks in advance to anyone who can help me.
Old Jan 3, 2009 | 07:57 PM
Default RE: '95 tune info pls
The plug gaps will be on a sticker under the hood.
The fuel filter is behind the passenger rear wheel bolted to the frame.
AutoZone can give you a diagram of the plug wire routing.
Are there no plugs and wires on the truck?
Old Jan 3, 2009 | 09:03 PM
llPANCHOll's Avatar
This is a great resource..
Rave Manual
Its a big file.. 590 megs, but its got everything..
Old Jan 4, 2009 | 08:22 AM
llPANCHOll's Avatar
Hope this helps If you havnt DLded the Rave Manual
Old Jan 4, 2009 | 09:13 AM
I would also suggest you order a factory only, cap and rotor and be very carefull removing the rotor, they can be hard to remove and you can damage the lower workings of the distributor if you hit or bang on the rotor.
Since this is a new vehicle for you, e-mail me with your tel number and I will send you a complete list of everything you need to do to this truck to make it current.
vader wagon
Feb 8, 2009 08:11 AM
provocateur
May 30, 2008 07:17 PM
xstreetz
Sep 16, 2007 06:22 PM
argoman
Defender
Apr 28, 2007 12:32 PM
Disco Kiwi
Jan 31, 2006 07:13 PM
