96 Disco 130K miles runs rough at 30 50 and 70 mph
#31
I don't see my post from earlier...forgive me if I double post.
I put in Champion OE plugs. The lady before me was using Bosch +4 Iridium. I will probably upgrade to those once I determine what is causing the misfire. I'm waiting on my new wires to come in so I can put those on and see how it does.
Any suggestions on how to test the coils?
#32
#33
#34
Just filled it up for the second time today. It got 12.6 mpg which is better than I expected with all the misfires and how poorly it's been running. Also, I started hearing some ticking/tapping after I changed the oil and ran the seafoam through the vacuum.
Any thoughts on what that could be?
#36
#37
#38
#39
http://www.bgprod.com/products/fuelair.html
I have not used it yet but have heard good things about it.
DO NOT use Lucas oil additive. If you need a oil additive then you need a different oil.
http://www.carbibles.com/additives.html
#40
Well the codes I'm getting are referenced earlier in the post. It was coolant sensor and random misfires on several cylinders. I reset them and I'll see what comes back.
The scanner does supposedly read live data. I think it's a pretty good one.
I was hearing a new tick and was worried about something tapping. But the more I listen to it, the more I feel like it's probably an exhaust leak. When I ran the seafoam through the vacuum line, smoke billowed out from the leaks and up into my face! :-)
ALSO - the more I drive the truck, the more I feel like it's a fuel issue. When I'm driving along, it starts stuttering/hesitating/missing almost like it's out of fuel. When I let off the throttle for a second then push it back down - it usually clears up. I'm wondering if possibly the fuel pump is having trouble keeping up, or maybe the line is clogged somewhere??
Do you think I could use this scanner to read live data to tell me what's happening to help diagnose the problemo? I've never really worked with one before.
