96 disco Grounded!!!!!! ECU
Old Mar 18, 2009 | 07:46 PM
joshuaaa316's Avatar
4th Gear
Exclamation 96 disco Grounded!!!!!! ECU
Posted earlier about Becm went exploring unplugged ecu to check contacts plugged back in, tried to start, had to toggle key finally turned over and over and over. radio wants a code and vehicle won't pop off. Now what?? nearest dealer is 120 miles.
Old Mar 18, 2009 | 07:52 PM
Start over, whats the problem and what have you done so far?
Old Mar 18, 2009 | 07:55 PM
Ok, just saw your other post.
www.atlanticbritish.com, tech tips, "96 ground issues"
Old Mar 18, 2009 | 08:31 PM
4th Gear
I checked the areas listed my largest concern is getting it to start. Like I stated have to toggle key then when it does turn over it doesn't fire. also the radio is asking for a code.
Check these ground locations:
Right inner fender, behind the battery. Battery and EMC on 1994 & 1995 models.
Below the battery, inside the right frame rail. Battery ground.
Right of the left cylinder head. ECU, A/C compressor clutch on 1994 & 1995 models.
Right frame rail, inside the wheel well. Starter.
Left footwell, behind trim panel. ECM, key switch, radio, OBDII data link.
Right footwell, behind trim panel. Starter solenoid relay, park-neutral position switch, alarm, data link connector.
Left side of luggage compartment, behind access panel for taillights, above light assembly. Fuel pump, fuel level sensor.
Old Mar 19, 2009 | 06:06 PM
So if you spray starting fluid or carb cleaner into the throttle body and crank it over will it start?
Old Mar 20, 2009 | 07:56 PM
4th Gear
Ended up being the inertia switch plug wasn't secured fully after cleaning. however after examining the headlight connector on both sides is melted where the black wire is, what would cause this? thanks
Old Mar 20, 2009 | 08:10 PM
A melted wire to the head lights is because of to much draw from the bulb.
Paul Grant
Aug 10, 2014 12:29 PM
JohnKimble
Nov 25, 2013 03:45 AM
OliveroLR3
Dec 19, 2011 09:19 PM
Phototone
Apr 8, 2008 04:10 PM
