96 Disco steering wheel & airbag replacement
Old Mar 2, 2008 | 07:42 AM
PITTDISCO's Avatar
Default 96 Disco steering wheel & airbag replacement
The steering wheel in my truck is a little wragged out so I bought another wheel and airbag for it. I would like a little info on how to replace these. Justdisconnect battery and do it? Or is there more to it than this?
Old Mar 2, 2008 | 07:56 AM
Default RE: 96 Disco steering wheel & airbag replacement
Disconnect the battery and let the trk sit OVERNIGHT!!! The airbag module needs to have time to discharge.
IT WILL KILL YOU! If you pull the steering wheel and you are to close or have a tool infront of you and it goes off...you will need more than a steering wheel.
Old Mar 2, 2008 | 08:33 AM
PITTDISCO's Avatar
I have the Land Rover workshop manual, and all it said to do was disconnect both leads to the battery. I wanted to ask here, because the book doesn't always tell you everything to look out for.
Old Mar 2, 2008 | 08:59 AM
Tread very carefully, go to , http://www.roverlandparts.com/index....S&Category=271
and order a good guaranteed used steering wheel.
You will need to have the SRS codes cleared after installing the replacement.
Old Mar 18, 2010 | 03:07 PM
lawson's Avatar
just a new member as regards to replacing the steering wheel with the air bag would i need a new code if i put the old steering wheel back on with air bag
Frank4
Jun 22, 2014 11:06 AM
rewi9d
Apr 5, 2012 01:33 PM
Jake1996D1
Jun 8, 2011 12:19 PM
NhudeST
Mar 20, 2010 04:23 PM
hilltoppersx
Nov 25, 2009 12:36 PM
