97 Disco Dual Exhaust
Old Feb 23, 2009 | 12:15 PM
roverohio's Avatar
Default 97 Disco Dual Exhaust
Anybody ever removed factory exhaust and added duals? Plan on duals after the Y pipe with magnaflow mufflers. Any issues?
Old Feb 23, 2009 | 12:17 PM
Why, whar do you think this will help?
Old Feb 23, 2009 | 12:41 PM
okdiscoguy's Avatar
http://www.people.cornell.edu/pages/...ver/engine.htm
You won't gain anything unless you add headers and work your intake. Even then the ECU won't recognize to gain from the mods.
Old Feb 23, 2009 | 01:36 PM
If you want to do ti just to do it fine, but like already mentioned by these guys you will not gain any MPG or HP.
Old Feb 23, 2009 | 01:58 PM
roverohio's Avatar
Already have a leak somewhere and looking to change the sound.
Old Feb 23, 2009 | 02:26 PM
okdiscoguy's Avatar
A lot of people have cut off the resonator (rear muffler) to get more growl. Just make sure to turn down the tip, or it will knock out your bumper lamps.
Also, the manifolds are prone to cracking. make sure your leaks aren't from there before you start. The gaskets aren't real cheap.
Old Feb 23, 2009 | 02:36 PM
AK Rover's Avatar
Saw a video clip a while back of a Discovery with dual pipes exiting on either side of the truck right in front of the rear wheels. I didn't care for the sound and exhaust leaking into the cabin through a bad door seal seemed inevitable. I will try to find the clip. I don't know how to describe the sound but it just wasn't right in my opinion. Perhaps taking the duals all the way to the back will help.
Old Feb 23, 2009 | 02:50 PM
discoxd's Avatar
that may have been my truck was it yellow? if it was u probably heard the manifold gasket leak i have over the actual exhaust, its pretty bad... i had exhaust like that until the last trail ride when the side exit pipe got pinched by a stump and snapped the hanger... so now i have shorty pipes that are turned down at the ends... some people dont like loud exhaust and some people dont want their tires to hum goin down the road, they want to be sneaky and discreet.... that is fine by me, but i am not that type of person...
Old Feb 23, 2009 | 03:50 PM
Snipers need to be sneaky and discreet.
Old Feb 23, 2009 | 04:56 PM
okdiscoguy's Avatar
Look at the link I posted. On the very bottom...... Duals right in front of the tires....
