97 disco failed emissions
on
When it comes to tuning a Rover, they are hard to please, I'll bet those plug wires aren't helping you.
Go out this evening with a bottle of batter, wet down all the plug wires, start the engine, when it's dark and shake the wires with a stick looking for any sparks.
Best set up is Magenacor 8mm wires and either Champion dual platinum or Bosh Platinum Plus 4's.
You need a good old fashined tune up, a real tune up, www.apexperformence.net and order the Magnecor plug wires, once you get them on the truck return the ones that you bought at the discount auto parts store, they are defective and you will get your money back.
You may or may not want to replace the plugs too, they should be ok if it has not been to long.
95% od O2 codes on a Land Rover are due to the need of a tune up.
KMD LR
02-05-2009 10:18 AM
