97 disco with squeaky rear suspension
so over the last few weeks I thought my rear brakes were squeaking, but over the last few days I have come to realize it is somewhere in the rear suspension, I can actually hear it when I push down on the rear bumper. I also noticed while looking under there that the passenger side shock looks a little loose, actually looks like the bushings are almost worn out. when you push down on the truck it looks like the shock pushes down through the bottom mount a little and the other side doesn't seem to do that.
Does anyone know what might be squeaking under there before I investigate this further?
not sure if these are factory or not, I bought the truck used they are black, and pretty dirty. I did however twist the lower part of the shock all the way around a couple of times and noticed a very similar squeak, I am guessing this is my problem, that the plunger inside the shock is squeaking against the housing
Those are long since dead factory shocks.
What do you use your truck for, do any wheeling, are you interested in lifting it for a better ride and clearance or just want to replace the shocks? Best replacement shock for the Disco's is the Old Man Emu, HD shocks, will last forever and give you a great ride.
I take it out in the desert every now and then but usually my off roading trips are mainly bumpy dirt roads and an occasional dry wash. I would love to lift it but the wife would probably not let me (she and my 2 girls have a tough time getting in it now) I would have to get steps for all the doors. I would say 80% - 90% of my driving is city streets and highway (45-50 mph on city streets 75-80 on highway out here). how much of a better ride will a lift give me? how much does a lift cost? and can I do it myself (does it require any special tools)?
Gabriel makes a decent shock but no where near what a Dico needs when off road.
There are only 2 brands of shocks that most common on a Rover, OME's and Bilsteins. Past those the rest are substandard for our slightly top heavy trucks, on and off the road.
