98 Disco loud roar
Old Dec 7, 2005 | 02:23 PM
Bugman's Avatar
6th Gear
Default 98 Disco loud roar
Ive owned this disco for over a year and have not had any problems. Then the other day while driving a roaring noise came from appears to be the drive train.The more you accelerate the louder it gets.Its a weird sound almost like a roar of air.The RPM's havent change any and trainny is shifting fine.There is no performance differance. All fluids have been checked and are fine.The noise get's pretty loud . Any suggestions?
Old Dec 7, 2005 | 03:38 PM
teamyonex's Avatar
Default RE: 98 Disco loud roar
I'd assume the exhaust manifold is cracked. I had a '97 and had one replaced under recall, and the other replaced later. Good luck.
Old Dec 7, 2005 | 11:50 PM
Nux's Avatar
Nux
Since you say it get louder while accelerating (under load), so most likely it's a bearing. Of course, it's hard to say what bearing it is. Have you noticed this roaring to be more prominent while turning a corner? If so, it's definitely a wheel bearing. Could be your transfer case input bearing. Get underneath and grab your shaft and yank it hard (sounds naughty, I know) from side to side, right at all the inputs. If you feel/see some slop, then you may need one/some of these bearings replaced. Also, see if the noise persists when you put it in neutral while the vehicle in motion.
Or, take it into a good shop and have them diagnose it. Most of these bearings are easily serviceable by any competent mechanic.
Daniel
Old Dec 7, 2005 | 11:55 PM
Nux's Avatar
Nux
...also could be your rad fan's clutch (if mechanically driven).
Old Dec 8, 2005 | 09:46 AM
Bugman's Avatar
6th Gear
Thanks for all your replies....It is the fan clutch. Got off cheap this time.
Profitsx
Oct 22, 2014 03:28 PM
thehun
Jan 19, 2011 07:48 PM
jhgerber
Feb 26, 2008 11:43 AM
Off Topic
Apr 28, 2005 04:02 AM
linfieldbrah
Apr 11, 2005 03:39 AM
