98 Disco SE7 Tail light cluster ground
Old Aug 28, 2009 | 11:41 AM
jacekk's Avatar
Default 98 Disco SE7 Tail light cluster ground
Can anyone please tell me where the ground is located for the right rear lamp cluster? If I am reading the Rave manual correctly it should be in the well behind the cluster, but there isn't one there that I can see.
I am having issues with the stop/tail light on that side.
The tail light shines at 50% brightness and when you put your foot on the brake the tail light and brake light don't work (on the right passenger side only).
Any Ideas?
Help!
Thanks
Old Aug 28, 2009 | 11:55 AM
AK Rover's Avatar
The connector shown is your ground connector. Check the contacts to make sure they are clean. Fill the connector with dielectric grease to help keep it clean.
Old Aug 28, 2009 | 12:09 PM
jacekk's Avatar
Thank you so much for your help!
Is E401 the ground connector as it states in the manual?
I was looking for an actual ground to steel there - so it is all the wires in the whole connector which are ground?
Old Aug 28, 2009 | 12:26 PM
AK Rover's Avatar
C487 is the ground connector and all the wires in the particular connector are ground wires. E401 is the actual earth ground the wires from that connector go to.
rambo
Oct 17, 2013 10:13 PM
RROJ
Jul 24, 2011 07:59 AM
bowser881
Jan 29, 2009 05:34 PM
zoomlenz4u
Jan 15, 2009 01:35 AM
kcirtap
Sep 26, 2007 09:39 AM
