99-02 vs 03-04 Driveshaft
Old Jul 10, 2019 | 06:59 PM
FlyingZebra34's Avatar
Default 99-02 vs 03-04 Driveshaft
Atlantic British lists these 2 drive shafts as separate part numbers. Are they compatible? They look pretty much identical. I have a spare out of a 2001 and was wondering if I can use it on my '03 need be.
Old Jul 10, 2019 | 09:06 PM
mln01's Avatar
I've never heard of any differences in the driveshafts for the '99-'02 vs. '03-'04 DIIs.
Old Jul 10, 2019 | 09:46 PM
mollusc's Avatar
isn't the transmission slightly longer on the later year trucks, which would make the driveshaft shorter?
Old Jul 10, 2019 | 10:06 PM
Shoot. I'll have to pull out the tape measure. I wasn't aware the transmission changed either? My 03 is still rocking the factory non greasable fittings. Figured it'll go eventually. No sense rushing it though since it's still relatively new. Just wanted to have a spare ready. Figured it'll fail at the worst time.
Old Jul 11, 2019 | 02:28 AM
JUKE179r's Avatar
That sounds vaguely familiar. I do remember reading something like that in someone's post.
Old Jul 11, 2019 | 01:00 PM
NewToTheTwo's Avatar
According to these guys, they're the same and measure 24" - (see last image)
https://www.proshaftllc.com/products...e-landing-page
Old Jul 11, 2019 | 01:23 PM
mollusc's Avatar
i know that i installed the same lucky8 front driveshaft on both my '99 and my '03 trucks. maybe most manufacturers don't worry about any slight differences in length by making the sliding spline section long enough to accommodate all years.
Old Jul 11, 2019 | 01:58 PM
Best4x4's Avatar
The difference in the HP22 & HP24 is maybe 1/2 an inch if that. Shaft should have plenty of spline slack to compensate.
Old Jul 11, 2019 | 02:29 PM
I'm also running a 2" lift so I think it'll suffice as a spare.
Old Jul 11, 2019 | 02:41 PM
Best4x4's Avatar
I’ve got 3inch lifts on the OEM shaft length and zero issues.
