99 Disco 1 (front wheels "shake" at 50mph)
Old Nov 14, 2005 | 04:32 PM
mcclellandm's Avatar
Default 99 Disco 1 (front wheels "shake" at 50mph)
My wife indicated that the front tires/wheels start to feel like they start to "shake" when accelerating on to the freeway. Not noticeable around town at all. The car currently has about 80k miles on it. I pulled the RF tire/wheel off this weekend to have a look around and didn't notice anything that looked out of the ordinary. Tried to see if there was any play in the hub (as much as I could by hand). I thought if the wheel bearings were really bad I would be able to feel it--seemed pretty tight. I know its hard to determine what something like this is from my lame description--it couldn't be I think more than a few items. Likely suspects?? Wheel Bearings? Shocks maybe?
Thanks Mark
By the way, if it is bearings any ball park on how much that service costs (christmas is coming - ouch!)
Old Nov 15, 2005 | 08:46 AM
Skelly's Avatar
Default RE: 99 Disco 1 (front wheels "shake" at 50mph)
Have you checked the UJ's ( CV's ) on the front prop ? My 89 had a terrible shudder under load and it turned out to be a worn CVJ. Maybe a balance weight has fallen off one of the wheels ( women have a habit of curbing their vehicles *Hides* ) and specific speed shudder is often a balancing issue.
GB.
Old Nov 15, 2005 | 06:03 PM
Benhamtroll's Avatar
Yeah, I'd check the wheel balance before spending money on anything else. I had a problem with my 2000 getting an awful shimmy at freeway speed, and a rotate and balance fixed it.
Old Nov 18, 2005 | 12:36 AM
Landzu's Avatar
I think I would check the tyres for balance also.
Old Nov 18, 2005 | 12:47 AM
teamyonex's Avatar
My Disco used to do that, and I went through the balancing routine, but it turned out to be loose tie rods or something similar. It was a 5 minute fix at the dealer. I hope the balancing works for you.
Old Nov 18, 2005 | 02:54 PM
Skelly's Avatar
Hmmm... worn drag-ball joints usually show up as 'wander' on the steering. Has this been the case ?
Old Nov 26, 2005 | 11:50 AM
Hank's Avatar
Have the tires balanced first, I bet that is the problem.... If not, could be any number of things or a combination of a few. Tie rod ends, wheel bearings, drag link bushings, UV-joint on Drive-Shaft, bent rim, broken belt in a tire....Some people think this could be related to a worn or broken Steering Damper, but I think the Damper is just a "band aid" for the problem.
Old Nov 26, 2005 | 04:54 PM
mikemeyer0's Avatar
I agree w/ hank, it could even be shocks, not too likley but i have seen it, If it dosent shake until you hit a bump, then I would look at steering dampner.
quixotic
Nov 1, 2021 03:31 PM
lostl13
Mar 6, 2012 03:37 PM
jeffh
Jan 20, 2011 12:35 PM
sfxgamer
Apr 14, 2008 04:38 PM
wax
Nov 20, 2004 05:32 PM
