99 Disco II Enging Humming around 75mph
Old Jun 1, 2015 | 09:33 AM
ammonation's Avatar
Default 99 Disco II Enging Humming around 75mph
Hey guys.
My disco II is running pretty good these days, with one minor exception.
When going around 75 mph and over the engine starts humming/vibrating. Feels like a pulse. Its not the tires or suspension, definitely the engine.
I get the car is now 16 years old just seeing if there is anything that can be done to help ease the pain of this old beast.
Old Jun 1, 2015 | 10:03 AM
DustyLBottoms's Avatar
First of all, you're insane to drive a D2 at 75MPH. :-p
Second, I doubt very much that it's the engine you're feeling. Check your u-joints, pinion and wheel bearings.
Old Jun 1, 2015 | 10:42 AM
Racer X's Avatar
I too get a little bit of a vibe between 75MPH and 80MPH in mine. It started after I replaced the U-joints in my front shaft, I wager that the shaft's balance is off by a hair.
Old Jun 1, 2015 | 12:15 PM
drowssap's Avatar
do you feel it in the seat or the wheel?
Old Jun 1, 2015 | 04:01 PM
dgi 07's Avatar
Same here.
Old Jun 1, 2015 | 04:06 PM
jdwilks's Avatar
I used to get a good humm, slight vibration at 70 or so and actually bought a second driveshaft but that didnt fix it. Replaced rear coupler and made it much better but I still have a slight noise at 75 or so but it will go away under or below that. I chalk it up to the balance being off just a hair as well and just live with it but mine isnt bad at all
Old Jun 2, 2015 | 05:11 PM
jfall's Avatar
It will smooth out at 85MPH.
Old Jun 2, 2015 | 05:26 PM
dgi 07's Avatar
Closer to 90..... more like 88mph. !
Old Jun 3, 2015 | 12:04 PM
ammonation's Avatar
When that baby gets up to 88mph your going to see some serious ****.
Old Jun 3, 2015 | 02:29 PM
Motorhead1's Avatar
Check your motor mounts.
If you have, or "suspect" an "out of balance" drive shaft, get it fixed, it's cheap. Your going to wear on other running gear items with a bent shaft.
