99 Disco II No Heat! It's getting Cold!
Just bought a 99 Disco II with 95K. Wife and I love it as do the kids. Had a Cherokee and an Xterra before, this is much better
Can't seem to get the heater core to heat up, at all. It's getting cold and Barb would like heat.
Could this be a bad thermostat always in bypass? If not I may be looking at a plugged core or lines.
The AC runs fine, all the servos go where they are told, the motor temp is always mid gauge.
Flipped down the glove box to watch the linkage and felt the heater core lines, the did not get hot after 20 minutes of idle.
Jeff
Jeff
RE: 99 Disco II No Heat! It's getting Cold!
Hi Mike,
Coolant is full, I have a small leak on the back of the intake so I keep on top if it. I get zero heat at the core even after a spirited drive. I am a compenent wrench having done a few engine swaps, motor rebuilds etc.... Not a lot of time anymore as I have moved on to sales. Was looking for a "That happened to me" before I pull and pressure/Flow test the hoses and core. Messy and the core looks like a PITA to remove.
It was cold in the Adirondacks and now here in the Pennsylvania Wilds. Heated seats take the edge off, but colder weather is comming up. We had a low of 39 this week.
Mke,
The hoses are different temperatures even after an hour of driving. Thought that odd, but it's my first british car. Need to get one of those cool laser pointed temp sensors.
Yes, the temp controls are both switched to high.
If I am correct there is no heater control valve and the heat or cold is controlled by the flaps in the air control box. My SAAB also works that way.
Jeff
Jeff
on
ORIGINAL: jskrebs
Mke,
Jeff
Mke,
Jeff
You are correct about the heater control. I am concerned that you might have a bad control head for your A/C, hope not cause they are expensive.
Let me know what you find.
Mike
on
ORIGINAL: jskrebs
Mike,
So you do no think the thermostat is bad?
Why do you think the head is bad? Not turning off the AC and it is overpowering the heater core?
Jeff
Mike,
Jeff
The t/stat on D2's are so cheap that it wouldn't hurt to replace it, my concern though is that if it were the t/stat the engine would be running real rich and you would smell it thru the exhaust. When driving around, do you ever notice your electric fans running, if so the engine would have to be at operating temp.
Mike
Thanks Mike,
Dropped the D2 off for PA inspection and my mechanic thinks the core is plugged with Barrs.
I changed the bulkhead to engine heater hoses when I first got the truck due to a small leak. He thinks the PO may have loaded the core up with stop leak. He is going to attempt to flush the core out with water.
The car does not run rich, actually it sound kind of cool, must have missed V8's
How big a deal is it to change the intake gasket? Have a small leak there as well.
