99 Disco II Starts, drives about 3 miles, dies in flight. Wont start again.
Old 03-18-2019, 07:08 PM
Taylor Hallmark's Avatar
Default 99 Disco II Starts, drives about 3 miles, dies in flight. Wont start again.
I was told to replace the o2 sensor. Any other suggestions? I just bought it and it only ran for 4 days.
Old 03-18-2019, 08:45 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
Is the check engine light on? Get the codes & then diagnose it properly. O2 sensors will not make a vehicle just up and die. Sounds more like a failing/INOP CPS.
Old 03-18-2019, 08:59 PM
Frank4's Avatar
I’ve experienced this. CPS is an excellent place to start, I changed mine and haven’t had this problem since. Easy and cheap fix.
Old 03-18-2019, 11:53 PM
Jakerover's Avatar
CPS(Crank Position Sensor), if your problem is that it will only drive cold it is CPS I you have someone with small hands it help. The hardest part of getting that sensor is actually getting your hand up to it to pull it.
Old 03-19-2019, 01:16 AM
JUKE179r's Avatar
Get a Bosch brand CPS. You’ll thank us later.
Old 03-19-2019, 05:35 AM
Saturnine's Avatar
Could be fuel pump
Old 03-19-2019, 06:40 AM
JUKE179r's Avatar
Originally Posted by Saturnine
Could be fuel pump
Could be diesel in his petrol tank. lol
Old 03-19-2019, 09:30 AM
Lisa Bunch's Avatar
I vote CPS also, mine would go 11 miles before dying. 20-40 minute wait and it would start and go 11 miles and die. Repeat.
Old 03-20-2019, 07:33 AM
shanechevelle's Avatar
I would start at cps also.
Old 03-21-2019, 04:28 AM
The Deputy's Avatar
Received 1,275 Likes on 896 Posts
I would try and find a job within two miles of your house...
shanechevelle (03-21-2019)
Quick Reply: 99 Disco II Starts, drives about 3 miles, dies in flight. Wont start again.
