?? about resetting the alarm
Old Dec 16, 2009 | 03:24 PM
salve7's Avatar
Default ?? about resetting the alarm
I had to remove my battery in my D1 the other day to charge it and when I went to put it back in the alarm wouldn't stop going off. I tried turning the key in the lock three times but it wouldn't lock or unlock like it normally does. It felt mechanical with no electrical assistance. I tried starting the car and using the remote but couldn't. I finally locked and unlocked the rear hatch and it kicked all the actuators on so the prob was resolved but now my remote only works some of the time and it feels like one or more of the actuators are going out. Can the drivers side actuator cause this or am I missing something simple? Seems like something is about to fail but I can't figure out how to tell. What should I do the next time this happens? Thanks for the help, Jay
BTW: Everything is working ok for the moment but I am still worried. Does it matter if the hood is closed?
Old Dec 16, 2009 | 07:43 PM
Mrmerlin's Avatar
is the remo0te battery in good condition? the hood also has a switch so try closing the hood when you redo the alarm replace the remote battery if its older than 2 years
Old Dec 16, 2009 | 08:35 PM
Baylink's Avatar
On the D2, the dash indicator light for the alarm will tell you if it thinks your fob battery is going dead; I don't know if the D1's did that or not.
Old Dec 17, 2009 | 01:23 PM
salve7's Avatar
The battery is prob shot so I switched to my D2 remote bat and it was still having problems. The remote only works some of the time anyways...
Old Dec 17, 2009 | 03:09 PM
okdiscoguy's Avatar
On a D1, you have to lock and hold it for 5 seconds with the key. You may have to repeat this. If you lock a D1 without doing this, the alarm will set. It will go off if unlocked with a key. The extra seconds keeps the alarm from setting. You can also get a new case and buttons for your alarm fob. Mine was getting really worn and I replaced it a few years ago. Works a lot better..
rphotographer
Oct 30, 2012 08:35 AM
lr3def
Jan 12, 2008 05:30 PM
bigugly82
May 29, 2007 10:19 PM
anonimaus
Mar 14, 2005 12:39 AM
voelks
Dec 30, 2004 07:55 PM
