ABS 3 Amigos -- Yeah Another Thread
Old Oct 8, 2013 | 10:55 AM
ukwildcats's Avatar
Default ABS 3 Amigos -- Yeah Another Thread
They popped up last night -- Read the codes with my ABS Amigo (great little tool) when I had front left hub sensor issues and I fixed fairly quickly.
Current Code -- 8PM, 8 Oct
114:Shuttle Valve Electric Failure
Previous Code -- 7:30 PM, 8 Oct
046:Front Left sensor output low
064:Front Right sensor electric fail
065:Rear Left sensor electric fail
066:Front Left sensor electric fail
067:Rear Right sensor electric fail
So Question is -- with these codes I can assume the sensors are all fine but there is an electrical issue (hopefully only 1 issue) that I need to address -- So does anyone have experience on where to start.
From other searches I find reference to doing Option B of "ABS Modulator Fix" but not sure yet if that is a problem -- looking at codes and trying to find a common issue (connector/wire/etc) that would result in all these codes being thrown.
Thanks for any guidance
UK
Old Oct 8, 2013 | 09:36 PM
pauldavidanthony's Avatar
I am looking for a solution to a similar 3 amigos problem;
016:Shuttle valve long term fail
Hopefully Disco Mike will chime in with some advice.
Old Oct 9, 2013 | 08:33 AM
Paul, I would suggest you read the ABS sticky at the top of this section and do both fixes.
UK, I would suggest you clear and re read the codes after driving it befor doing anything.
Old Oct 9, 2013 | 02:40 PM
FlyingZebra34's Avatar
x2 on the ABS fix in the sticky.
Also when you tear everything down make sure to clean connectors and look for any corrosion, bad grounds and connections will cause issues with the sensors.
Best of luck!
Old Oct 9, 2013 | 03:12 PM
ukwildcats's Avatar
DM --
I cleared the codes Monday night -- when my daughter got home Tuesday with the D2 I went to check the codes and there were none -- will monitor every night.
Going to the -- Discovery II - ABS Amgio V1 USB -- website I can not find a common cause from all the codes so I will keep searching.
UK
calebbo
Dec 21, 2010 05:40 PM
Rovin4life
Feb 8, 2010 06:32 AM
rj95lss
Jan 25, 2010 10:31 AM
audioclay
Oct 27, 2009 10:09 AM
whatmeworry?
Aug 1, 2009 08:23 AM
