ABS Amigo readout
ABS Amigo readout
Hello,
Just received my ABS Amigo in the mail and had to try it out. Here is the text file it generated, any help in understanding/diagnosing would be appreciated. I have been getting the 3 amigos intermittently with no consistency in what sets them off. I've had the truck for about 500 miles
2002 Discovery SD - 88000 miles
Thank you
|* ABS Amigo Box V1 RSW Solutions LLC Copyright 2008. *|
|* www.RSWsolutions.com *|
|* Version V1.1 *|
1.--Current Faults---->
Active Faults:
None
Logged Faults:
114:Shuttle Valve Electric Failure
<-END Faults
..--Previous Faults--->
Active Faults:
022:ECU Gnd or Reference Gnd bad
064:Front Right sensor electric fail
065:Rear Left sensor electric fail
066:Front Left sensor electric fail
067:Rear Right sensor electric fail
Logged Faults:
None
<-END Faults
Active Faults:
Comms Error
Logged Faults:
Comms Error
<-END Faults
Thank you
|* Version V1.1 *|
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
Logged Faults:
None
<-END Faults
Active Faults:
Comms Error
Logged Faults:
Comms Error
<-END Faults
The electric failures are a power disconnect, battery, relay, etc. The other code is a well documented fix.
https://landroverforums.com/forum/sh...ad.php?t=26847
rlsmoyermd
01-27-2008 09:35 AM
