ABS Amigos arrived...code 035?
I just got my ABS Amigo today...Anyone know what this code means?
"035:Rear Right out valve open circuit"
I also have the 114 Shuttle Valve code, but that's well documented. I didn't have any real luck with searching for 035 though. I'm guessing this is telling me I need a new ABS Sensor, maybe even just brakes, but any help deciphering would be greatly appreciated...
OK...I started to ask this again, but broadened my search to the internet as a whole and I think I've found the answer, or at least enough to say that I've got most of it.
I'm guessing the attached document was written for a somewhat earlier system, but I was able to locate the fault code I had asked about. (The "035:Rear Right out valve open circuit" from my ABS Amigo = 3-5 in the table on page 9.)
I can't find anything in the documentation that supports the known 114 fault code, which I would have liked to see so that we all would know whether this document is correct for the DII and complete.
With a DII, you'll obviously want to ignore the 'blink code diagnostics'. Despite what it says in the Wabco document, I know of no way to turn on the blink codes in the DII.
Anyway, hopefully some of the codes in the attached document are useful to someone.
EstorilM
09-20-2011 09:47 AM
Rover_Hokie
Off Topic
03-29-2011 09:14 AM
