Test for TC?
Old Jan 26, 2011 | 01:38 PM
larson3000's Avatar
Exclamation Test for TC?
Hi All,
My 2001 Disco seems to be acting different this winter up here in Anchorage. I have the same winter tires on as last year. Nokian Hakkapeliitta with studs (no screwing around on Anchorage roads in the winter).
Anyway, I feel like I am getting more slip and less grip than I did last year. Corners and turn are fine. It is the starting from a stop where I feel like I'm not gripping like I should. The TC light is coming on and I can hear it working (the modulator?). But the Disco isn't popping off the line like I remember last year and I'm almost sure I can hear some wheel spin. I've denied believing it because I can't believe I could get the wheels to spin with the tires, studs, and TC.
If you all remember, I had a Three Amigos issue after coming down a hill.https://landroverforums.com/forum/sh...ad.php?t=32866. The dealership reset the fault and I thought everything was fine. I'm starting to suspect maybe things aren't.
Is there any way to test whether the TC system is working the way it is supposed to? I'd hate to get into a sticky situation this summer in the bush and have my four-by-four-by-far not operating as it was designed to.
Thanks!
Old Jan 26, 2011 | 03:17 PM
NiteTrain's Avatar
maybe start at the bottom of a icy hill and try to go up while somebody watches to see if front is spinning. are you running the same air pressure that you have in the past?
Old Jan 26, 2011 | 04:14 PM
handsome rob's Avatar
If I am correct if the three amigos are there then you will not have the traction control working either. I had a friend who went to shop to get his three amigos fixed, paid for it and they were gone, only to realize they put electrical tape over the lights to make them go away. I am not saying this is your issue but if they are gone you should see the traction control at least try to modulate the slippage.
Do as Nite Train said though and try a hill to see what happens.
Old Jan 26, 2011 | 04:38 PM
lipadj46's Avatar
start flooring it around corners in the snow and ice. You should hear the ABS kicking in and the ETC light will illuminate.
Old Jan 26, 2011 | 06:05 PM
Snafu / Disco Fries's Avatar
How are your actual brakes? Worn or uneven wear? I had that issue on an MDX we had a few years back.
Old Jan 26, 2011 | 07:55 PM
Its the tires...tires wear as you drive and brand new tires from a year ago with 10,000 miles on them will not grip like they used to.
Even with 5,000 miles on the studs they will not grip as well.
If you ran them in the summer then you basically have a all season tire now.
Old Jan 27, 2011 | 10:58 AM
Check for tire air pressure first, run them around 38 to 40 pounds all the way around. And has already been mentioned, how are your brake pads, if warn or glazed you will not have the traction you want, what about your brake fluid, when did you last flush itout, if old and or slightly burned, your brakes won't be as responsive either.
Even if you don't have a check engine light on, go check for codes, you may have a 1590, sleeper ABS code lurking in your system.
Let us know what you find.
DiscoMike
Jan 15, 2014 08:34 PM
tom
Nov 12, 2006 01:14 AM
blackonblacklr3
Mar 27, 2006 10:33 PM
DiscoMike
Dec 18, 2005 07:08 PM
