ABS BOX? HAZARD LIGHTS WONT SHUT OFF
Old 09-06-2008, 09:53 AM
J dog's Avatar
7th Gear
Default ABS BOX? HAZARD LIGHTS WONT SHUT OFF
last night the cardboardpanel under the passengers side fell down..I tried to push it back up with my foot. Next thing I know the hazard lights come on and wont shut off unless wires are unplugged from the box under there...but then car wont run...tried disconnecting the battery and the hazrd fuse under the hood...still the lights wont stop flashing..HELP
Old 09-06-2008, 10:09 AM
Default RE: ABS BOX? HAZARD LIGHTS WONT SHUT OFF
When you jammed it with yor foot you shorted something out.
Does your horn work?
I am thinking that you set off/shorted out the alarm. It will shut the engine down and flash the hazards and honk the horn.
Dis-connect the battery and let it sit for a hour, re-connect and see what happens.
If they still flash after that then let them flash for 15 min or so, the alarm is spposed to shut off and re-set after a short time.
After that I think that you are looking at a trip to the dealer.
Old 09-06-2008, 10:21 AM
roverguy7's Avatar
sounds like you tripped the inertia switch... what year disco?
Old 09-06-2008, 10:30 AM
J dog's Avatar
7th Gear
its a 96
Old 09-06-2008, 10:38 AM
roverguy7 you might be a genius...there is a button on the firewall under the hood on the left, press it down and hold for a second or two.
Thentry to start it.
Old 09-06-2008, 11:11 AM
J dog's Avatar
7th Gear
Ok not sure where that button is...I looked on the firewall?...horn works and Hazard fuse removed wont stop the lights flashing. Car starts and all when box wires are intact...the lights just keep on flashing...ahhh~!
Old 09-06-2008, 11:20 AM
The firewall is the wall between the engine and the passenger cabin. Stand in front of the truck, open the hood. On the left side of the engine on the firewall is a black rubber button
Press it.
But I do not think that is your problem anymore. If it runs then it cannot be the inerta switch, that cuts power to the fuel pump. It is a safety switch to stop the engine in a accident.
Sorry but it sounds like a trip to the dealer.
Press the switch anyway.
Some cars turn on the Hazards when in a accident. If the truck thought you were in a crashbecause you triped the inertia switch...
Old 09-06-2008, 11:49 AM
J dog's Avatar
7th Gear
found and tried the the botton...no deal...thanks for all your advice!
Old 09-06-2008, 11:51 AM
roverguy7's Avatar
yeah, its not the inertia switch if its running, youre going to need to get it looked at, im not sure what 'box' you unplugged or what kind of damage to the wires there might be
Old 09-06-2008, 11:52 AM
Sorry we couldnt help. Keep checking back and somebody else might have a better idea, but I imagine that you will have it looked at Monday.
Also double check that you dont have the hazard button pressed in.
Quick Reply: ABS BOX? HAZARD LIGHTS WONT SHUT OFF
