ABS code 114 solved
ABS code 114 solved
I tackled a few issues today (transmission pan, again, yuk) and also the Three Amigos. I had a periodic ABS code 114 "Shuttle Valve Electric Failure" that I could activate by braking hard from 30 mph. I removed and replaced the shuttle valves today and was surprised by what I found.
The picture below shows the old shuttle valves. The valves were leaking, and they are worn. I can get an "open" reading on my meter after a few clicks on the valve itself. I replaced the valves, and now the issue is gone. Thanks to this board for the solution!
This advice is critical, the fluid I removed from my system was dark brown, and dirty. I made sure to do a full flush with DOT 4 in hopes to curtail further issues.
Lincoln Tarantino
04-01-2012 09:13 PM
DiscoBenjamin
10-14-2011 05:53 PM
