ABS Code Reading Machine in Atlanta.
Old Nov 20, 2007 | 03:49 PM
leadoverdistance's Avatar
5th Gear
Default ABS Code Reading Machine in Atlanta.
Before I did the discs and pads yesterday, I had 4 lights..... Started out with Parking brake (fluid full, and microswitch in handbrake lever console works) and ABS initially both came on............. later then got Traction Control, and HDC light. It drove for a week with all 4 lights on. There was no ABS at this time. I drove it after doing the brakes yesterday, Atlantic British Ferodo kit. and still have no abs whatsoever. No lights have extinguished obviously. Does anyone know of a code reading machine outside of the dealerships? I don't want to go back there. Misdiagnosed fuse box problem, and it was a harness plug, my wallet's loss.
Thanks a lot
Paul
(BTW DiscoMike should be on LR payroll. Great tech advice, been helped many times without you knowing it. )
Old Nov 20, 2007 | 03:50 PM
5th Gear
Default RE: ABS Code Reading Machine in Atlanta.
Doh! 2003 Discovery, 93000 miles.
Old Nov 20, 2007 | 05:06 PM
There are many of them, just call around and find a shop that has a lap top type scanner like an Auto Logic and you'll be able to have your codes read and cleared when ready.
NiteTrain
Oct 3, 2012 04:22 AM
aublec22
Dec 12, 2011 07:46 PM
tweakrover
Jul 2, 2010 01:47 PM
rover
Freelander
Apr 28, 2008 08:42 PM
