ABS killing my battery
Old Nov 13, 2010 | 12:31 PM
SDinDS's Avatar
Default ABS killing my battery
So after weeks of wondering why my battery would be almost dead after sitting for 3-4 days, I bought a circuit tester and went thru every fuse. The ABS fuse under the hood has a constant .5 amp draw. I suppose I could just pull the fuse every time that I'm not going to drive it for a few days, but I would rather fix it. No fault codes from my amigo reader, no 3 amigos, ABS works fine. I'm thinking it's a relay. When I put the fuse back in, I can hear a click coming from somewhere inside the dash. After looking at the Rave, the only relay I can find is the ABS return pump relay. I'm wondering if the relay is stuck or if there's a sensor gone bad. (although I would think that would show up on the amigo reader ) Anyone else had this issue? As long as I drive it every couple days, the battery will keep a charge, but you only drain a battery so many times and then it's junk.
Eric
Old Nov 13, 2010 | 12:42 PM
lipadj46's Avatar
There is supposed to be a tsb for this but requires a trip to the dealer
Old Nov 13, 2010 | 01:07 PM
SDinDS's Avatar
Sorry, I forgot to mention I had that done. Dealer re-programmed the SLABS. That "faint alarm noise" issue coming from the ABS has been taken care of. I'm thinking either a relay or my ABS unit has seen better days. After 185kmi, it wouldn't surprise me.
Eric
PeetzLR3
Dec 11, 2023 11:21 PM
powderhound
Jun 20, 2014 07:52 PM
DiscoIIBrandon
Mar 11, 2011 05:15 PM
benflynn
Aug 22, 2008 03:30 PM
