ABS light
ABS light
The ABS, Hill decent, and TC lights are on. I'm thinking it is the ABS sensor line, is there a way to check which one is it or is the mechanic shop the only way to find out? also the best price i found so far for one is $69, is there any other place that is cheaper for any instructions someone can give me?
Thank you in advance
RE: ABS light
Hello there,
I´ve had the same problem on my TD5. And there can be only one of two things:
1-Sensor malfunction.
2-ABS module malfunction.
In my case, it was just a sensor malfuncion, that was quicky solved... By Land Rover! (once the error is registered in the car´s "computer", only Land Rover can erase it).
But, unfortunatly, i know cases of ABS module malfuncion (The module controls the ABS / TC / HDC)... and here in Portugal... it goes for €1941 !!! FOR THE PART ALONE!
Hoping for the best,
Messias.
Messias.
RE: ABS light
I have a 99 Disco 2 (94,000) with the same problem. I also had a weird vibration happening when I was accelerating up to about 30mph. Took it to the dealer for the first time ever. Big Mistake. I had to have the CV joint and drive shaft replaced and also had a problem with the Mass Air Flow Sensor. I replaced those at a cost of $1000. I did not do the ABS Shuttle valve replaced. That is what is causing the 3 lights to be on. they want about $2400 to do that. They did give a loaned (new LR3) for about 6 days no charge.
