ABS light
Old Oct 3, 2005 | 12:36 AM
AzCamel's Avatar
Default ABS light
The ABS, Hill decent, and TC lights are on. I'm thinking it is the ABS sensor line, is there a way to check which one is it or is the mechanic shop the only way to find out? also the best price i found so far for one is $69, is there any other place that is cheaper for any instructions someone can give me?
Thank you in advance
Old Oct 3, 2005 | 09:35 PM
rinmud's Avatar
Default RE: ABS light
with a diso I need know what testbook says the sensers maybe but brakelight switch probably. also be carefull the sensors int the rear also have issues with the trigger wheels
Old Oct 14, 2005 | 10:14 PM
fsflip13's Avatar
i got same problem what did you find out???
Old Oct 15, 2005 | 11:40 AM
messias's Avatar
8th Gear
Hello there,
I´ve had the same problem on my TD5. And there can be only one of two things:
1-Sensor malfunction.
2-ABS module malfunction.
In my case, it was just a sensor malfuncion, that was quicky solved... By Land Rover! (once the error is registered in the car´s "computer", only Land Rover can erase it).
But, unfortunatly, i know cases of ABS module malfuncion (The module controls the ABS / TC / HDC)... and here in Portugal... it goes for €1941 !!! FOR THE PART ALONE!
Hoping for the best,
Messias.
Old Oct 15, 2005 | 02:39 PM
Randy Lover's Avatar
that happend on my TD5 but the hill decent also lit up aswell, are the traction control light red or amber ?
Old Oct 16, 2005 | 09:43 AM
messias's Avatar
8th Gear
Yes, all three lights lit up (Amber)
Old Oct 16, 2005 | 02:08 PM
well we just took it to the dealer as soon as posible and i think he cleared alll the sensors, he didnt explain very well
Old Jan 29, 2006 | 01:36 AM
katbri's Avatar
We had ABS, TC and HD light on our 2000 DISCO II. The dealership hooked their little machine to it, said it needed front brakes....problem solved!
Good luck to any who have this problem.....and hope it's not the modulator!
Old Mar 2, 2006 | 06:00 PM
scottvaughan's Avatar
8th Gear
I have a 99 Disco 2 (94,000) with the same problem. I also had a weird vibration happening when I was accelerating up to about 30mph. Took it to the dealer for the first time ever. Big Mistake. I had to have the CV joint and drive shaft replaced and also had a problem with the Mass Air Flow Sensor. I replaced those at a cost of $1000. I did not do the ABS Shuttle valve replaced. That is what is causing the 3 lights to be on. they want about $2400 to do that. They did give a loaned (new LR3) for about 6 days no charge.
Old Mar 2, 2006 | 10:58 PM
mikemeyer0's Avatar
common D2 problem, somewhere around 75% of D2's on the road had this problem, tae to dealer, they will cure.
