ABS Light resolution
Old Jan 25, 2015 | 06:59 PM
redrover75's Avatar
Default ABS Light resolution
Since I bought this truck about 8 months ago I have had the three amigos plus the brake light was on. Upon reading nearly everything on the subject I replaced the shuttle valve, but not the falcon gaskets as there was no obvious leakage.
I replaced much of the brake fluid as well.
Long story short, all four lights remained. A generous board member here sent me his ABS amigo. I pulled codes and found the attached.
1.--Current Faults---->
Active Faults:
None
Logged Faults:
015:Pump fail pump running when not On
022:ECU Gnd or Reference Gnd bad
045:Rear Left sensor output low
Rear Left Sensor Bad Output
114:Shuttle Valve Electric Failure
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
040:Pump relay open circuit
My point is that the codes indicate speed sensors among other faults. And I did not, knock on wood, replace or repair them.
So, a couple days later, no codes. Hopefully, that continues.
File Type: txt
Old Jan 27, 2015 | 09:36 AM
redrover75's Avatar
In follow up, of course in the snow and few cycle of ABS the lights are back, Ill have pull the codes again and see what has changed.
Old Jan 27, 2015 | 09:56 AM
RoverMasterTech's Avatar
It needs a left rear hub.
Old Jan 27, 2015 | 12:24 PM
redrover75's Avatar
It needs the entire hub? Let me pull new codes and I would appreciate your input on that.
Old Jan 27, 2015 | 12:57 PM
jafir's Avatar
It's got an active fault for the shuttle valve switch.
Just replacing the switches won't fix it sometimes. You'll have to do the bypass.
Old Jan 27, 2015 | 07:02 PM
redrover75's Avatar
Update: Drove it for a while in the snow, got the traction control to engage. The TC light went on momentarily. Otherwise, amigo free.
The stored codes are:
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
If I understand correctly, I need to do the bypass, is that accurate?
Thanks,
Old Jan 30, 2015 | 04:43 AM
mln01's Avatar
Yes. The Option B bypass is not difficult, just tedious. Looks like you may still need a LR sensor too. Or perhaps double check its connector first. Unless you did something to address that code it may come back.
Old Jan 30, 2015 | 06:19 AM
drowssap's Avatar
what abs codes did you start with?
me 2
Sep 27, 2012 07:08 AM
marlymarl
May 28, 2011 10:34 PM
Surfin Elvis
Jun 23, 2005 11:08 PM
