ABS lights on after brake line repairs.
I had a couple of leaky brake lines on my 94 Disco, which I had a independent shop repair. These were evidently associated with the brake resevoir compartment nearest the booster. The leaks were under the vehicle where the lines run along the frame of the vehicle. These were leaks big enough to see fluid squirt out when the brake pedal was depressed and the fluid level in one compartment of the brake resevoir would go down.
Now I have good brake action, pedal feels quite normal, but the red ABS lights are on. The car stops straight and true. Are the ABS lights called the "Three Amigos"??
What should I do about this, if anything? There are no RR dealers anywhere near here.
OK, so maybe I am just not interpreting what I am seeing correct. Maybe it isn't a flaw.
Is the ABS red light (the letters ABS) supposed to glow red when the car is on? If it isn't, then how do I make it go out. The brakes appear to be working just peachy fine.
is it the yellow abs light in the center of the dash? or red "brake" light on? if its the yellow abs light you have a fault in the abs system, you should have normal mechanical brakes but no abs. if tis the red light ck brake fluid levelit also may be associated with the parking brake same "brake" light is used
ORIGINAL: landrover1502
ORIGINAL: Disco Mike
On a D1, if the single ABS light comes on, you need to get it bacl to the shop before you experience a failure or loss of stopping power. ASAP
