ABS pump failiure 1 monitor line
Old Sep 5, 2017 | 06:42 AM
WILLEP's Avatar
3rd Gear
Default ABS pump failiure 1 monitor line
Need help, I get fault "pump failiure 1 monitor line"
I replaced shutlevalve AND modulator SWO500040.
Didnt help so replaced SLABS ECU for a used part.
Still having problem and same fault code.
Checked al wiring and conectors, al in good condition.
Is it possible that problem is inside pumpunit?
Eny ideas how to move forward? I have Nanocom.
Help much appreciated
Best regards patrik in Sweden.
Old Sep 6, 2017 | 03:26 PM
OffroadFrance's Avatar
Hi Patrik
Lets start from the top.
Exactly what parts have you replaced?
Have you cleared the faults since replacing these parts as they remain resident in the SLABS until you clear them and will show every time you connect the diagnostic kit.
Old Sep 7, 2017 | 06:46 AM
WILLEP's Avatar
3rd Gear
I changed al parts in picture.
And also the WABCO SLABS controler.
Then using Nanocom reseting fault.
Fault comes back immediately and Amigos never disapear.
Fault code is "pump failiure 1 monitor line" but sometimes also "output valve left front short to internal supply"
Pump seams to work ok.
regards, patrik
Old Sep 7, 2017 | 08:23 AM
Sixpack577's Avatar
Do the mod and get rid of the 3 amigos.
Should solve your problem.
It's a sticky in the D2 section.
Old Sep 7, 2017 | 09:48 AM
WILLEP's Avatar
3rd Gear
Did read that thread.
Iam familiar with that mod but this is not shuttlevalve switch problem. For shure, al parts new.
best regards patrik
CGeneral
Apr 11, 2009 01:05 PM
mrgeemoney
LR2
Jan 9, 2009 02:46 AM
allstarmac08
Oct 10, 2008 02:03 PM
Doak
Audio/Visual Electronics
Nov 20, 2006 09:46 AM
