ABS Sensor Front Discovery I
Mike
I took my Disco to a mechanic because my pedal mas kicking for no reason, he told me that my front abs sensor from my right wheel was not working right. We change the pads and road tested, it stop the kicking but the antiblock light is on all the time. He told we need to replace that abs sensor, now i'm driving with the antiblock disable.
How badly do you want ABS?
The ABS sensors for a DI are $450 each, you wont find to many used ones and they are all going to be around the $400 price range for a brand new sensor.
The next thing to go bad will be your ABS modulator, $1500 for that.
So...here is what you do, open the hood and on the passenger fender is a fuse box, open it, find the ABS fuse and remove the fuse.
Close the fuse box back up and you are good to go, no more brake pedal kicking in for no reason when you are trying to stop.
Your ABS light will be on all the time and you will NOT have ABS, just like now, but you wont be out $500 for parts and labor.
