ABS, Traction Control, Hill Descent Warning Lights
Old 03-03-2011, 10:09 AM
dakejog's Avatar
Default ABS, Traction Control, Hill Descent Warning Lights
The 3 warning lights mentioned above have all come on and I cannot seem to get them to turn off, even thought the components seem to be working.
The D2 Workshop Manual refers to Fuse #27 for each of the functions, and indicates that if they fall below 1.8V the warning lights will come on. The owner's manual says that this is a 10A fuse, and the repair manual says that it is a 15A fuse. I have replaced it with each of them, and it still doesn't seem to fix the problem.
Does anyone have an idea of what else could be causing this problem?
Thanks.
Chris
Old 03-03-2011, 10:44 AM
achapman's Avatar
Old 03-03-2011, 11:14 AM
thospb's Avatar
Before you proceed to disassemble your ABS, get the codes read. There are numerous causes for the "3 Amigos", it could be as simple as a Brake Light Switch.
Old 05-08-2011, 03:04 PM
arly973's Avatar
7th Gear
Ive just bought a 99 disco 2 and those 3 came on too, driving in really bad rain last night, is it something to worry about, they went off and havent come back on since??
thank you
Old 05-08-2011, 05:39 PM
EastCoastWarrior's Avatar
5th Gear
Most the time these "Three Amigos" lights come on for a small, or temporary problems. Usually with warning lights, if you disconnect the negative on your battery leave it off a while then reatach it and start up the car, all false or corrupt lights will get swiped from the computers memory. If you end up leaving the lights on a few days they get programmed into the computer and stay on your dash until Land Rover gets em off for you or you use this ( http://www.rswsolutions.com/index.ph...d=56&Itemid=55 ) to take em off yourself. Its expensive but you dont have to worry about em ever again, plus its like hundreds more at a Land Rover repair shop. At least its not that big of a problem, Ive had mine on for months and nothing has happended(at least so far). Anyways good luck with your problem.
Old 05-09-2011, 02:32 AM
arly973's Avatar
7th Gear
Many thanks, mind at rest for now!! think it was down to severe rain..
Old 05-09-2011, 06:24 AM
Originally Posted by EastCoastWarrior
Most the time these "Three Amigos" lights come on for a small, or temporary problems. Usually with warning lights, if you disconnect the negative on your battery leave it off a while then reatach it and start up the car, all false or corrupt lights will get swiped from the computers memory. Ive had mine on for months and nothing has happended(at least so far).
the first part is false. disconnecting the negative to the battery will do nothing. the only small problem could be brake dust or a warped rotor. it's more likely a hub, ABS sensor or a shuttle valve failure.
nothing will happen if the lights are on except for the loss of traction control and possibly ABS.
Old 05-09-2011, 07:51 AM
sloan74's Avatar
/this
x2
Old 06-09-2013, 02:17 PM
British Rhino's Avatar
Is there a chance this device will work on the 2004 DII?
Old 06-09-2013, 02:59 PM
Colorado David's Avatar
Yes, it will.
Quick Reply: ABS, Traction Control, Hill Descent Warning Lights
