AC
Old May 28, 2007 | 06:07 PM
samue23's Avatar
Default AC
My AC is only blowing 58 degree air on its lowest setting, is this normal or do I need a charge? and if so, should I take it to the dealer or do it myself?
P.S. Had a volvo 240 that was blowing 40 degree air on its lowest setting.
Old May 28, 2007 | 06:52 PM
Default RE: AC
What year and at what outside air temp?
Mike
Old May 28, 2007 | 07:28 PM
samue23's Avatar
Default RE: AC
I have a 02 Disco II, approx. 88-90 degrees F.
Old May 28, 2007 | 07:40 PM
Default RE: AC
The normal a/c will drop the outside air by 40 degrees. Since you are driving a D2 that has some a/c issues in town, get it out on the road and test it with a thermomiter.
For the most part, Discos don't loose freon.
Mike
Old May 28, 2007 | 10:08 PM
mordor110's Avatar
Default RE: AC
Hey Disco Mike, I have a 95 Disco (5spd). What should my high & low side pressures bewith say85-90°F ambient? At what RPM should you check also? Thanks.
Old May 29, 2007 | 08:16 AM
Default RE: AC
I don't even remember those numbers any more, sorry. Might want to talk with a good a/c mechanic for help there.
Mike
