AC Air Flow not up to par
Old Aug 14, 2017 | 02:04 PM
LandGrover's Avatar
Default AC Air Flow not up to par
I have a 2004 Disco SE with 130000 miles. The issue I'm having pertaining to the air flow coming from my AC. I have poor air flow from my vents. All speeds on the ECU work. I understand that there is no cabin filter to change. My question is, what would prevent the flow of air? The ac is cold so Temp is not an issue .
Old Aug 14, 2017 | 02:44 PM
Sixpack577's Avatar
The "cabin filter" is under the hood.
In plain sight on top of the firewall. It' a strip of foam the width of the hood, about a couple inches tall.
In the same plastic molding that is under the wiper arms.
Old Aug 14, 2017 | 02:51 PM
Sixpack577's Avatar
There is no foam/filter in mine in the picture.
I have a new one, but haven't put it in yet.
I still have alot more to finish on mine.
Old Aug 14, 2017 | 03:50 PM
OffroadFrance's Avatar
IMO install one PDQ or you'll be chewing leaves and crap as you drive along quite happily
There is an AB vid and it only takes about 10-15 minutes to do.
Old Aug 14, 2017 | 03:54 PM
If it's like mine, the diverter flap foam seals perish and peel off and slowly block the vent tubes which causes poor airflow.
Old Aug 14, 2017 | 05:00 PM
LandGrover's Avatar
Thanks for the advice. What's the procedure removing the debris that has accumulated inside? Is it the removal of the dash? Can I access it some other way?
Old Aug 14, 2017 | 05:32 PM
usaf_disco's Avatar
following this.
Old Aug 15, 2017 | 12:14 AM
acg's Avatar
acg
Re: What's the procedure removing the debris that has accumulated inside? Is it the removal of the dash? Can I access it some other way?
Please see attached instructions and pics from the AULRO site.
P/S. The instructions indicate the blower motor is secured to blower assembly by (3) T27 torx screws. My blower was held by T25 screws.
File Type: pdf
Old Aug 15, 2017 | 12:32 PM
Sixpack577's Avatar
I have a new cabin filter. I just haven't put it in yet.
I'm not driving it as I haven't finished reassembling it yet.
I'm also having the windshield replaced in the next couple weeks, so that cowl has to come off.
Old Aug 16, 2017 | 11:57 AM
russburcham's Avatar
There may be a crack in the "air box" behind the dash. This is plastic and gets brittle over time. Pray it is not, bc pulling the dash is a PAIN
