ac compressor pulley
Old Feb 10, 2020 | 03:31 PM
jastutte's Avatar
Default ac compressor pulley
is the ac compressor pulley serviceable? i have chirping at startup from, i believe, the ac pulley and and i'd like to either fix it or replace it with just a new pulley.
thanks,
Old Feb 11, 2020 | 01:32 AM
miron's Avatar
You can get a whole "new"compressor for $30. It's faster and probably cheaper to do it this way. If you really want to stick to just replacing the pulley, it's a Denso compressor used in about a thousand other car models so you should be able to find a replacement no problem. I've recently worked on a Cadillac compressor (turning it into onboard air comp) pretty sure it had the same clutch as my D2.
Old Feb 11, 2020 | 03:57 AM
JUKE179r's Avatar
@miron please let me know where I can find a fully functioning $30 Denso 471-13360 A/C compressor. lol
Here is a parts list I have for the A/C compressor...
clutch coil 12VDC: Denso #447300-7880
clutch bearing: Santech #MT2027 (30mm ID x 52mm OD x 22mm thick)
bolts: M6 x 20mm
A/C Comp Clutch Installation Kit Santech #MT0985 – AutoZone $10
More info about the Denso A/C compressor and clutch removal... http://ww2.justanswer.com/uploads/jo...622_clutch.pdf
Old Feb 11, 2020 | 09:10 AM
jastutte's Avatar
bolts: M6 x 20mm
thanks. a quick search also brought up your pulley cross reference sheet on D-Web.
i'll be putting that on a document and saving it.
Old Feb 11, 2020 | 11:05 AM
miron's Avatar
Here is one for, well $40 bucks...
https://www.ebay.com/itm/293144704491
Sorry missed the price by $10
Old Feb 11, 2020 | 12:59 PM
JUKE179r's Avatar
Old Feb 11, 2020 | 03:22 PM
Extinct's Avatar
Yes, the pulley and bearings are serviceable without replacing the compressor. Comes with advantage you don't have to evacuate and recharge the system. Worth it to buy the compresssor and keep as a spare.
Wesley Vincent
Dec 1, 2018 09:41 PM
lowcountry_disco
Apr 2, 2018 01:02 PM
Wilson7287
Feb 28, 2017 09:29 AM
seanyh
May 19, 2013 10:30 AM
tflhund
Aug 4, 2011 06:04 AM
