Squeaky air con pulley on a TD5...can they be replaced?
Old May 19, 2013 | 09:02 AM
seanyh's Avatar
3rd Gear
Default Squeaky air con pulley on a TD5...can they be replaced?
Got an 02 plate facelift series 2
Has the TD5 engine
the air con pulley squeaks in use...doesn't do it all the time and is more noticeable when cold...if you switch air con off it shuts up...
sounds like the bearing in the pulley has got...
can you replace these or if not would removing the bearing and soaking in oil stop the squeak...
how do you remove them...
many thanks...
Old May 19, 2013 | 10:30 AM
Do you mean the clutch pulley on the AC compressor? There are parts out there, but an AC shop may be able to sell you just the pulley/clutch parts. Or a breaker yard. You can "listen" with a yard stick (meter staff?) held to one ear and touched to suspect objects whilst Rover is running. This may confirm your selection of device to swap out, like an idler pulley, power steering pump, etc.
LR considers the AC unit a complete swap out, they just list the compressor and O-rings in the Microcat parts database.
kevlor80
Mar 2, 2017 10:37 PM
awer25
May 3, 2010 12:41 PM
RANGER46
Nov 29, 2008 02:09 PM
littlemissdisco
Feb 21, 2007 06:32 PM
