Ac problem
Old Mar 25, 2020 | 06:42 PM
landroverdude's Avatar
Default Ac problem
Hey guys I have an ac problem, it will work at night or when it's not hot outside and be ice cold but not when it's hot and the car heats up it will not , my Aux fan is broken is that what cools the air? I honestly don't know too much about this.
Old Mar 25, 2020 | 09:01 PM
zski128's Avatar
Aux fan only provides extra cooling for engine/radiator when the AC is running. Is your ac compressor running when you turn on the air. Pressure check the system?
Old Mar 26, 2020 | 07:20 AM
ahab's Avatar
The AUX fan runs when the AC is on to help remove heat from the AC condenser, as this is one of the principles of how the AC system functions. If you are moving the fan is somewhat redundant however when sitting still it is necessary to keep the system functioning efficiently. After verifying the compressor is running when you engage the AC, the next step is to get a set of gauges and see what the system pressures are. Too high due to blockage means the system will shutdown the compressor. Too low due to inadequate charge will also shut it down. You can wing it and got to the auto parts store and get one of the cans of R134 with the gauge on top and see what that says as you try and add refrigerant. If the system is simply low then you may be able to get a season out of it. The only reason it would be low however is due to a leak, so you may be wasting $40 if the leak is severe. Having someone read the system pressures is the safest way forward.
PhilipC
Jul 22, 2018 06:23 PM
DieHard
Jul 14, 2017 09:19 AM
a_wick_2010
LR2
Jun 11, 2015 02:58 AM
raim212
Aug 5, 2012 02:53 PM
bigalpha
Jun 30, 2009 03:03 PM
