Ac question - refrigerant lines
Old Apr 8, 2011 | 06:44 PM
Dan02's Avatar
7th Gear
Default Ac question - refrigerant lines
Hey guys, I'l preface this by saying I know very little about air conditioning, which will probably be evident, but I'm learning. I've got a 2002 disco v8 series II that's leaking any refrigerant I put in. It looks like it's coming out of a refrigerant line that loops under the entire condenser - but when I looked to see what line this was in my workshop manual, it doesn't show anything that does this. It's about two feet long and runs parallel to the front bumper. The manual shows a setup for a diesel, but says they are similar.
I may be way off, but it looks like one end is coming out of the receiver drier, running down and along the condenser (but not attaching anywhere), looping and coming back and going to the maybe back into the receiver drier or something slightly above it - but definitely not the compressor. I know this is probably vague, but any insight/direction is appreciated.
Dan
Old Apr 8, 2011 | 08:30 PM
Bundu's Avatar
Banned
I think it's the power steering cooler you are looking at.
Power Steering Hose Pump To Box for Discovery Series II, Steering & Suspension Parts
Old Apr 8, 2011 | 08:57 PM
Dan02's Avatar
7th Gear
Bingo, it may just be coincidence that it's leaking as I put in the refrigerant - or more likely, it's not what's leaking. I'll look more closely, thanks a bunch.
Old Apr 9, 2011 | 03:11 PM
DarylJ's Avatar
You're probably in the right place. Just behind that is the condenser and the accumulator. The high side line from the compressor goes down along the frame on the driver's side and the line bolts to the side of the condenser here:
(obviously that's a picture with the radiator and transmission cooler removed.....and well, you know...the motor is out)
The condenser then feeds to the accumulator just in front of the condenser. You can see that with the grill removed:
The horn I pointed out normally goes where the text "horn" is. It's out so I have access to the bolts that hold the radiator supports, so you can ignore that for your purposes.
The silver fitting you can see on the accumulator goes to a soft line that switches to a hard line and runs down the inside of the driver's side BODY (not the frame) back towards the cabin to the evaporator. You can actually see it coming back out of the front firewall no the first picture. It's the silver hard line above the marked "high side line".
But you see there are a lot of lines and fittings there. All of them have gaskets. So it could be as simple as a bad gasket or a loose fitting, hopefully.
Grab some dye and a UV light and put a little in after cleaning everything up in there. You should be able to find it no problem.
Old Apr 10, 2011 | 12:29 PM
Dan02's Avatar
7th Gear
Thanks for taking the time to spell all of this out. Really appreciate it.
Old Apr 10, 2011 | 04:11 PM
aublec22's Avatar
"horn ignore that!" lol
Oasisplayer311
May 30, 2015 08:44 AM
TRIARII
Feb 26, 2015 11:13 AM
EstorilM
Jan 29, 2014 08:56 AM
ProRiderRoadKing
Aug 16, 2013 11:48 PM
Duke
Jul 21, 2013 05:04 PM
