acceptable oil psi?
found it in the manual!!
Lubrication
System type .................................................. ................... Wet sump, pressure fed
Oil pump type .................................................. ................. Eccentric rotor
Oil pressure .................................................. .................... 2.75 bar (40 lb/in2) at 2500 rev/min with engine at
running temperature
Oil filter-internal .................................................. .............. Wire screen, pump intake filter.
Oil filter-external .................................................. ............. Full flow, self-contained cartridge
Looks like 40psi at operating temp, I have less than half that.
Lubrication
running temperature
on
You are going at this *** backwards.
Go rent an oil pressure tester and first thing one morning, prior to starting the engine, hook it up. You have to run 4 tests, cold at idle, 2000RPM's when cold, idle at operating temp and 2000 RPM's at operating temp, then get back to us with thos 4 sets of numbers.
Pull your oil pan and check the oil pump pick up screen for blockage.
