ACE gets angry in stop and go traffic
Old Aug 12, 2018 | 06:07 PM
H Hill's Avatar
Default ACE gets angry in stop and go traffic
Stop and go traffic, in my '00 Disco w/ ACE, 260K miles, daily driver. I'm in one particular spot where the road goes downhill ever so slightly and the traffic backs up for about 4 blocks in rush hour so it's stop and go for a bit.
Nearly every time after about 3 or 4 moves (vehicle length then stop, repeat as traffic dictates), the ACE light comes on red and a warning beep. It will continue until I shut off the truck, count to 5, and restart. Then it's gone. Just changed the fluid about 40K ago, pump is fine all the lines are fine, won't set it off again until the same situation on the same bit of road. I'm a school teacher and I get stuck in rush hour traffic on my only road home. Backs up at a 3 way stop at a RR track, so no way around the intersection. Concerned that it may be a signal of something worse.
Sensors failing or bad connections? Where to look. I have a local indie shop that has the correct electronic test systems, but they are booked way out and its somewhat a costly test.
Other than this, everything on the truck works great!!
Any help or ideas appreciated!!
Old Aug 12, 2018 | 06:15 PM
Best4x4's Avatar
You have two yaw sensors one above the sunroof control panel in the front, and mounted to the body just below the front passenger floor. You also have a sensor on the ACE valve body itself. Have you ever changed the ACE filter on the ACE valve body or taken it out and sprayed it with some brake cleaner?
You can convert back to a standard swaybar setup if something dies and it’s $$$$ to fix.
Old Aug 12, 2018 | 07:12 PM
CollieRover's Avatar
I don’t have ACE, but without a code it seems impossible to say. You’re better off investing the $$$ into a tool Tom that reads those codes than paying a shop to try to replicate the issue, or just throwing parts at it.
Old Aug 12, 2018 | 07:15 PM
Best4x4's Avatar
Problem with the ACE ECU if it’s not a hard fault it will reset upon a key cycle.
Old Aug 13, 2018 | 07:45 AM
H Hill's Avatar
There's no tool that will read codes for the ACE that I could afford, and yes, no hard codes will stay from the ACE ECU. Did the ACE filter with the ACE service 40K ago.
Not affected by rain, as this happens randomly, so no leak so far from the sunroof onto the ACE ECU which I believe is under the glovebox above the passenger footwell.
Also, does occur during warm weather, not winter.
Old Aug 13, 2018 | 09:10 AM
That’s too bad.
What is the service interval on ACE? 40k is way past due for power steering which I think is every 20k. That sounds like a really good place to start.
Old Aug 13, 2018 | 04:23 PM
T-rex's Avatar
I had problems even a professional with the Land Rover reader couldn't diagnose - I replaced the accelerometer under the passenger side and it's been good since.
Old Aug 14, 2018 | 06:37 PM
H Hill's Avatar
That may be the route I take. That't the only thing I haven't worked with yet. All other connections good. May start at that one. Hate to throw expensive parts at it but there are only 2 of them and the one under the passenger side is easier to get to.
Since the truck is 18 years old and 260K, probably time to replace the sensor.
Thanks. Will keep you all posted.
Old Aug 15, 2018 | 11:44 AM
T-rex's Avatar
Those little sensors are extremely expensive if you can even source them. I found mine in the junk yard and they've been fine.
Old Aug 16, 2018 | 06:40 PM
H Hill's Avatar
Going to pull the electrical connections, clean them really well, use dielectric grease and see if that helps.
If not, calling Rovers North and dropping $189+ for each sensor.
I'll let everyone know what if find!
The wanderer
Aug 18, 2022 07:04 AM
H Hill
Apr 11, 2015 09:40 PM
cornercase
May 24, 2013 11:43 AM
jycsalas
Dec 17, 2008 11:00 AM
POPPY1
Oct 28, 2007 11:38 AM
