ACE Leak
Old Apr 12, 2016 | 04:04 PM
difrentbob's Avatar
5th Gear
Default ACE Leak
Sorry if this ends up here twice, my first attempt seems to have vanished.
I replaced the high pressure hose from my ACE pump this weekend. Today the pipe that goes into the valve block started spraying PAS fluid. I believe the collet failed, but I would like some input before I start ripping the ACE valve block apart. I have the following questions:
1. Would the collet fail on its own, or should I look for another problem?
2. Does anyone other than AB have ACE filters? (dealer wants $120)
3. If I pull the clamping plate off the front of the ACE block to replace collet will I have to take to someone with Testbook to bleed the system?
The pipe that is leaking is in the picture, lower right.
markdeg
Nov 15, 2022 03:56 AM
Tin_Man
Apr 12, 2014 11:12 AM
thehrdway
Apr 26, 2011 01:41 PM
tbuckt007
Apr 13, 2010 11:46 AM
alrd
Nov 17, 2006 11:25 AM
