ACE leaking
Old Apr 21, 2008 | 01:24 PM
dkdirt63's Avatar
8th Gear
Default ACE leaking
I have a 99 disco II and my ACE is leaking some where at or right by the pump, I'm not sure where. It's fluid is all over that side of the engine bay. Where should I be looking for the leak and is there a way for me to fix it without buying a new one?
Old Apr 21, 2008 | 07:41 PM
Default RE: ACE leaking
Check your hose clamps.
Old Apr 21, 2008 | 09:40 PM
PalmettoDisco's Avatar
Check the banjo bolt underneath the air intake tube. It can become loose and release gobs of fluid. It's a known TSB for dealer mechanics. The banjo bolts on early ACE's weren't torqued properly at the factory and they will work loose and leak.
Loosen the air filter cover and lift up and over. You will see the banjo bolt right underneath; very, very easy to reach. You will see the hose from the banjo bolt lead up to the ACE reservior. Turn the truck on and you likely will see it drip while you watch. A simple fix, just retighten the bolt. Do not overtighten, or you will bend the washers sealing the banjo.
At the dealer, they retorque to (as I recall) 24 lbs\ft. If it still leaks, they replace the washers and retorque again.
If it looks dry and clean under there, then like said before, check your hoses. The hoses will lead to the filter and manifold under the passenger side, then out to the hydraulic rams at the sway bars.
Jeff
greenwade
Aug 28, 2020 09:38 AM
Tin_Man
Apr 12, 2014 11:12 AM
thehrdway
Apr 26, 2011 01:41 PM
tbuckt007
Apr 13, 2010 11:46 AM
alrd
Nov 17, 2006 11:25 AM
