ACE problems weeeeeee!
Old Aug 14, 2020 | 12:47 PM
humroot's Avatar
Hi.
You replied to a 7 year old thread. Might have more luck starting a new one.
FWIW, you can get rid of Ace by adding sways bars front and rear.
Old Aug 15, 2020 | 10:28 PM
T-rex's Avatar
ACE can be a pain sometimes. But I'd rather have it than not I think I'd make sure there is fluid in the pump - loosen the high pressure line and see if fluid comes out - maybe even spin it by hand and see what happens. After that I'd check all the electrical connections on the valve block and make sure they're connected. Has the ACE ever worked since you've had the truck? Weird. Known good pump? or did you get a hold of a dud?
Old Aug 17, 2020 | 10:45 PM
Geordon Sparks Orbical Taylor's Avatar
Rookie mistake. I didn’t prime it well enough beforehand. Got it going and I’ve got to be completely honest with ya, the ACE makes the truck drive so much nicer. I live in a mountainous region and the steep hard corners are a blast now. Thanks for the tip
Old Aug 18, 2020 | 11:36 AM
T-rex's Avatar
Sweet! Glad you got if figured out!
Tin_Man
Apr 12, 2014 11:12 AM
thehrdway
Apr 26, 2011 01:41 PM
tbuckt007
Apr 13, 2010 11:46 AM
Ahhsk
Sep 24, 2008 08:15 PM
alrd
Nov 17, 2006 11:25 AM
