Active Cornering Enhancement ACE problem
I have both the hydraulic rams for the sway bars leaking, anyone know how to repair them?
When I take a corner a bit quick, the ACE red light starts to blink for 2 minutes then stops, at engine restart it goes solid orange.
The leak seems to be coming out of the seals inside and not the lines.
Thanks for the help.
There are kits to replace the ACE with normal sway bars.
Here is a diagram of the DII suspension with and without ACE.
Land Rover Discovery II Front Axle Suspension Parts Available from RoversNorth.com
I had to replace my front ACE ram this fall with a used unit. Once the rams are replaced you'll have to bleed the system. The rams have to be fully extended in order to bleed them - I used the Hawkeye. I couldn't get the Land Rover sealing washers in time so I used 1/4 BSP sealing washers from my local hydraulic supplier and they've sealed just fine.
Spensive
03-19-2010 06:36 AM
