Added Bluetooth input to Disco II
After seeing many threads all suddenly related to the topic. I figured I should write what I did to add BT to the Disco.
Just reserving this spot for the moment, I'll snap photos and show what device I used to add it in. It meant giving up the 6 disc changer though which I could care less about. When we hit the CD button option, we get BT instead and that's fine with me, it means using my phone and or tablet for music which with spotify is all I want anyway.
I'll try to get this filled out by tomorrow or Friday.
-Greg
-Greg
The following 5 users liked this post by 05TurboS2K:
99TEXASD2 (01-08-2024),
ReconDoc83 (09-25-2020),
Richard Gallant (09-25-2020),
Tomzsix (09-23-2020),
TylerDurden17 (01-10-2024)
-Greg
-Greg
I have that one already... Since i bought the GROM around 7yrs ago and has been in a box waiting to get installed... I would like to give it some use. Only got the courage to do this little project after having to replace the headliner due to sunroof leaks...
Hi macutan. I installed a GROM in my truck over 10 years ago, back when it required two separate boxes, not just one. So it's been a while since I've had the radio out, but I do recall there being A LOT of room back there to place the modules. Have you had the radio out to look?
Now I need to figure out why my radio does NOT turn off when i take the key out of the ignition... I am unsure if this behavior was there before i connected the GROM so I will now have to revert to the original situation (plugging back the CD unit) before I continue to tinker to figure out what else may be going on.
I was able to run the cable to the area under the steering wheel, that may be "cooler" ? try to see if that cable you have reaches there before returning it, it is a great addition to my Disco
