Advice on Differentials
Old Dec 23, 2006 | 06:12 PM
askewm's Avatar
Default Advice on Differentials
It appears that the pinion bearing on my front differential is going out fast...I am able to move the front drive shaft (Prop Shaft) off its centerline by about 1/8". This must be where all the clanking noise is coming from on deceleration.
I have found a Front Differential Assembly replacement at LandRoverParts.com for around $350. How much more difficulty is involved if I wanted to bite the bullet and put in a TruTrac differential?
Old Dec 23, 2006 | 06:16 PM
askewm's Avatar
Default RE: Advice on Differentials
Whoops...said I found diff on LandRoverParts.com when it is actually RoverLandParts.com
Old Dec 23, 2006 | 06:56 PM
If you buy a used third member, there is no gear set up so if you are at all mechanical, you may beable to install it without going to a shop.
Putting in a new diff like a T.T. involves setting up the gears, making all the proper measurements and installing it. Most shops chanrge around $350 to install a new diff.
Right now, I believe a new T.T. is around $450 plus new bearings.
Mike
Old Dec 23, 2006 | 09:47 PM
askewm's Avatar
Thanks Mike!
It the TT a direct replacement for the Stock Front Diff Assembly Third Member? The pictures of the TT online look significantly different than the stock diff assembly. Just curious before I go order one...
Old Dec 24, 2006 | 01:03 AM
ORIGINAL: askewm
Thanks Mike!
Any of the aftermarket diffs are larger and stronger then a factory diff.
Call me tomorrow.
Mike
Old Oct 8, 2007 | 09:29 PM
taj's Avatar
taj
5th Gear
Can you tell me why the front drive shaft turns the front wheels do nto?
Old Oct 8, 2007 | 09:31 PM
okdiscoguy's Avatar
what year and mileage. If you park on a slope, you will have some play in the front shaft.I have about 1/8" of movement.
Old Oct 8, 2007 | 09:35 PM
taj's Avatar
taj
5th Gear
It's a 1996 with 157K (not original engine)
Old Oct 9, 2007 | 10:16 AM
okdiscoguy's Avatar
crap. Tou told me about 6 months ago this much play was normal. This is rotational play I am talking about here. Do I need a new diff now? It has been this way for 2 years.
Old Oct 9, 2007 | 11:17 AM
I misread one of the posts, disregard me statement.
