Advice needed for ARB Awning mouting to SD roof rack
Old May 4, 2016 | 11:50 AM
TRIARII's Avatar
Default Advice needed for ARB Awning mouting to SD roof rack
My new awning arrived today, be it without any mounting hardware. Looking for a simple but secure way to mount the awning to my rack. Did a google search and it appears most people have a non tubular rack, and there is more products available for those type of racks. Seems the tubular roof racks have less product support and generally less options. I was hoping there might be something at the local hardware store that could be used.
Is it recommended that I drill into the roof rack tubular construction? I prefer not to. Any tips would be appreciated.
Old May 4, 2016 | 12:08 PM
number9's Avatar
Don't drill into the tubing.
Something like Adel clamps may work for you and available in many tubing size.
https://www.google.com/search?q=adel...w=1920&bih=928
Old May 4, 2016 | 01:03 PM
binvanna's Avatar
Adel clamps are the right concept, but most are thin sheet metal. They won't hold a heavy awning well.
Look for a roll-cage brackets, tube clamps, etc.. The Synergy J-hooks from PolyPerformance could be used, but there's tons of options if you search. For example:
http://www.summitracing.com/search/p...rder=Ascending
There's several pages to look through there. You'll narrow it down if you identify the tubing diameter. If you're looking for a fast and cheap solution, try U-bolts from the hardware store.
Another good option would be to simply weld a flat plate on the side of the tube. If you don't weld, it might still be simpler and less expensive to pay someone to weld a plate on there than to try to find more complex bolt-on clamps.
Old May 4, 2016 | 04:34 PM
Robert Booth's Avatar
I'll send you some pics of how my Foxwing awning is mounted in about 20 minutes.
Old May 4, 2016 | 04:39 PM
Modular Awning Mounts Would work for your use case.
My awning mounts to cross bars which then mount to my sd rack. Pics to follow
Old May 5, 2016 | 01:19 PM
TRIARII's Avatar
Thanks for the suggestions everyone. Still pretty annoyed that the awning kit was missing the mounting hardware; which according to the provided instructions was suppose to be included. I checked out all those custom fabricated mounting devices online and concluded that it would be considerably cheaper to improvise and make my own mounts for the awning.
Old May 5, 2016 | 03:31 PM
Street Wolf's Avatar
Pipe repair clamp, get them for a dollar or so at Home Depot, Lowe's, etc... etc...
Old Mar 21, 2018 | 04:59 PM
xisled's Avatar
Robert. didn't see any info for the foxwing mounting for youe rack... stil;l have pics?
Old Mar 22, 2018 | 09:02 AM
i mounted 3 Rhino Rack cross bars to the safety devices rack. The Foxwing mounted to the cross bar.
Old Mar 22, 2018 | 04:59 PM
TRIARII's Avatar
Do ya mind sharing some pics?
TRIARII
Nov 17, 2014 08:52 PM
johnnyjohnny
May 26, 2014 09:14 AM
Paul Grant
Jun 17, 2012 12:35 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
