Advice for a new owner?
Old May 25, 2014 | 04:37 PM
smonk's Avatar
Default Advice for a new owner?
I just bought a Discovery 2. A 2004 SE7 with 61000 miles on it. We bought it primarily to use off road, on trails to go camping. Not looking to do any big league 4x4 rock climbing or anything like that, just camping in out of the way, off the beaten path. We plan on putting larger tires on it and doing some modifications, but I'm not sure what yet.
This is our first Land Rover and I was wondering if you guys might offer some constructive advice for a new owner, such as maintenance, tools, books or suggested reading? I'm also looking for a few good parts houses that specialize in LR, both on and off road parts.
Thank you for your time and help.
Steve
Old May 25, 2014 | 04:51 PM
Dane!'s Avatar
2" HD lift, 265/75r16 tires, rebuild your front driveshaft, and check the sticky up top of the D2 section of the forum, you'll want to do that service list (pretty big, but a Land Rover needs a lot of love).
Old May 25, 2014 | 05:08 PM
G Reeves's Avatar
Never mnd the lift or tyres yet or mods ets. First thngs to do is get an Ultra gauge EM. Crawl underneath and check the front drive shaft then look about replacing for a fully greasable one. look to put a 180 thermostat in sooner rather than later then work through the high milage service
Download a copy of the Rave (link in my signature) which is the work shop manual for these vehicles.
Enjoy the pleasure and pain of owning these great vehicles
Old May 25, 2014 | 05:47 PM
ls1morethanyou's Avatar
Plugs/wires/oil change/check front driveshaft/ check ac aux fan is a good start.
Then do front/rear diff and transfer case. If you can do the 180 inline thermostat mod/ check the axle breathers and that should be good for a while if there aren't any other known issue.
Old May 26, 2014 | 08:44 AM
OffroadFrance's Avatar
If you're just using it for green laning and nothing extreme don't spend lots of dosh on it just maybe some offroad tyres which can run also on tarmac nothing too extreme.
Firstly, run a codes check then clear all the existing fault codes, then drive it for 50 miles and re-check the codes for faults and then do a service and fix the codes, if any, check over the brakes, steering gear and drive train etc - no panic it's low mileage. My survival motto, 'if it ain't broke don't fix it' ..........or spend money on stuff you may never need or use. Enjoy and save your cash for when you may need it later. Good luck.
PS get a good quality socket set - Snap on, Mannesmann, Britool etc (metric and AF) also spanners etc. You'll accumulate more tools as you go along when needed.
Old May 26, 2014 | 09:50 AM
dusty1's Avatar
get some good walking shoes.
kidding! get maintainence up to date,keep shafts and cooling in good condition, download rave and have fun.
Old May 26, 2014 | 12:43 PM
Big Jim Swade's Avatar
Since it's a SE7 I would assume it has SLS on the rear. I would keep it and enjoy the ride. Skip the lift and just go with an inch taller tire like 255/70-16's if you have 16" wheels or 255/60-18's if you have 18". Make sure your CDL lever moves to engage the CDL. Most people don't use it much and it will freeze from lack of use. You have a nice ride if it has that low of miles.
Old May 27, 2014 | 06:01 PM
parkerlander's Avatar
Drive it for 500 miles and see what breaks and go from there.......if u have any money left after that; what they said
Old May 27, 2014 | 08:35 PM
smonk's Avatar
Smile Thank you!
Guys I appreciate the responses. The consensus seems to be... 1. Just enjoy it till something needs to be fixed and 2. Change the damn drive shaft
I've yet to take it to my mechanic as we just got it but that's first on my list. Also buying Ultra gauge EM and going through the check list.
Can you guys suggest a parts house? Someone who has quality parts at a reasonable price.
Thanks again for the comments, as new owners things like this forum are a big help.
Old May 27, 2014 | 08:56 PM
Dane!'s Avatar
Lucky8llc.com, RoversNorth.com, Roverparts.com they are some good parts warehouses for both aftermarket and oem.
